In 5.3 suddenly there is no more Dynamic Scope mode any longer for the IC9700 which I use as Transceiver nr 2 .... it is still there for IC7610 which is the transceiver nr 1.
LA0FA wrote: ↑Fri 5. Mar 2021, 22:56
When the 7610 gets a similar firmware update, the dynamic mode will be removed also.
Hi, first now understood the point . Apologise .... after upgrading IC-9700 with the newest Firmware with Scroll Mode, the adjustment of RumLog of course makes a lot of sense. Great work ! I still wonder if I miss something wanting to see the up- and downlink moving tracked when using mouse wheel on scope window when in Satellite mode. Is there a feature either in the Transceiver or Rumlog making this possible ? 73 de LA0DA
Good idea. But it seems we can't get the tracking mode (invers, normal, main or sub only) out if the trx using the CAT commands. So it will be very uncomfortable.
