V5.1 works fine
tnx
RUMlologNG version 5.0
Re: RUMlologNG version 5.0
When you have experienced problems under Big Sur use at least the version 5.1.1 and report please: https://dl2rum.de/RUMlogNG/RUMlogNG.zip
Thanks to Andy, M0XTY for his great support tracking down this bug.
Hi Tom, does new version of RumLogNG working native on new M1 chip ?
Tom, Sp5ets
Tom, Sp5ets
Thanks for fast answer.
Regards, Sp5ets.
Regards, Sp5ets.
Hello, is it possible to remove some rows and visible parts in main window ? I am using two computers and on mb pro main window is just to big. I don't have space for qso listings if I open dx-cluster terminal.
Or is it possible to rescale down whole main windows ? Maybe it will be new future option ?
Regards. Sp5ets
Regards. Sp5ets
Right (control) click into the table header to make your selection.Hello, is it possible to remove some rows
No, that's not that what I mean. I would like to remove in first upper part main loging window row with "satellite, mode" etc. and remove "DXCC Pfc callsign" etc.
I changed monitor to 27' 4K and I use scaling to 200% for good view (1080p). Its just look's to big for that scaling, and I wonder if it's any solution for that.The best solution would be size scaling for whole main and other windows. Tom, is it possible to put that option in next RumLog version ?
Regards, Sp5ets.
Regards, Sp5ets.
