N1MM compatible and waterfall bandmap
n2iw
Re: N1MM compatible and waterfall bandmap
Post by n2iw »
I think we need some adjustments for the spot coloring.
In following scenario, NU1X and W5PS are blue on RumLog bandmap (I need the slot, never worked), but grey on Waterfall Bandmap
In following scenario, HK1N and 9Z4Y are black on RumLog bandmap, but green on Waterfall Bandmap. I do have QSOs with them on same band and mode, so this time Waterfall is correct on this? At least it's not consistent with RumLog bandmap.
In following scenario, IK4GRO is green on RumLog bandmap (I worked this slot but didn't get LoTW or QSL), but grey on Waterfall bandmap.
Post by DL2RUM »
Next try: dl2rum.de/RUMlogNG/RUMlogNG_Test.zip I hope to see blue now.
Pse note: Already worked stations are not marked in the band map, only in the dx-spot window.
n2iw
Post by n2iw »
Yes I do see spots with either blue or red color. It seems if a spot is new country or band or mode, then it's red. If it's no new anything, then it's blue. I don't know if that's what your intention or not, but it looks pretty good to me! I don't like the grey (dupe) anyway, and don't use the green is not a big deal either. Thanks Tom!
