DX Spots not updating "DX SPOTS"
K6LE
Post by K6LE »
Using App store version 1.1 (46).
I like the ability to click SH/DX on the Telnet window and have the DX SPOTS window updated. However, it seems that since 1.1 that is the only way DX SPOTS is updated.
If I watch spots come in in the Telnet window they usually don't appear in the DX SPOTS window until I click the SH/DX button.
BTW, speaking of the DX SPOTS window, will the country's name be included in a later release?
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Re: DX Spots not updating "DX SPOTS"
Post by DL2RUM »
This works fine here. Maybe the same like this: http://dl2rum.de/forum/viewtopic.php?f=10&t=642 ?
K6LE
Post by K6LE »
It seems the problem was cured by switching Telnet Clusters.
I was using N7TR - an AR cluster and switched to VE7CC - a CC cluster and now it is working fine.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
k4zrj
Post by k4zrj »
Also works with DXSpider from W1DX.
Post by DL2RUM »
Thanks for pointing out this Rick. It will be fixed with the next update.
K6LE
Post by K6LE »
Thanks Tom.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Post by K6LE »
K6LE wrote:Using App store version 1.1 (46).
Incidentally, I decided to start using "Spots" again as my Telnet client and have RUMlogNG connect to it so I would have better control over cluster filters. This also solved the country name problem!
There's a check box in Spot for country name and with it checked the name appears in the comments section. So, that concern is handled.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Post by DL2RUM »
And I spend weeks of hard work to add this killer feature:
dx.tiff
dx.tiff (176.1 KiB) Viewed 3894 times
dx.tiff
My idea was to let this function active for few weeks. In this time you can memorize all prefixes-
K6LE
Post by K6LE »
Looks good.
That way I won't have to run "Spot" if I don't want to. :)
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
