I thought I'd try RUMPed this weekend in the CQWW 'test. I'm using a K3, no interface, AFSK A.
1) How to key the K3? I have set the modem to K3(Tx + cM(Rx). The macros don't respond to %TX %RX like RUMLog.
2) The DX spots item in the Window menu is disabled. I can't connect to a cluster. I have entered one.
3) I don't understand how to handle the state/zone in the exchange. I read the post in another thread about it.
73, Mike NF4L
New to RUMPed
New to RUMPed
73, Mike NF4L
Re: New to RUMPed
Use the CQWW-RTTY contest template (plug in type) when creating the contest file! Enter first the Zone and then the State separated by a space.
To see the cluster, open the terminal first from Menu-->Window-->Terminal
To key your TRX use the VOX, or cocoaModem supported PTT options.
Re: New to RUMPed
Thanks Tom!
OKDL2RUM wrote:Use the CQWW-RTTY contest template (plug in type) when creating the contest file! Enter first the Zone and then the State separated by a space.
OKTo see the cluster, open the terminal first from Menu-->Window-->Terminal
When I transmit from RUMPed, no tones are generated. Xmit from cM, tones are generated.To key your TRX use the VOX, or cocoaModem supported PTT options.
73, Mike NF4L
Re: New to RUMPed
OK, got it going using Preferences-->RTTY-->cocoaModem Wide modem with VOX on the K3.
73, Mike NF4L
73, Mike NF4L
73, Mike NF4L
Re: New to RUMPed
i worked the CQWW RTTY 'test and RUMPed worked great!
Does it use the same format DXCC.rsd file as RUMLog? Since my file for RUMLog is more up to date, can I just copy it to the RUMPed folder?
Is there a place (or could one be added) to type in text to send if something isn't in a macro?
73, Mike NF4L
73, Mike NF4L
73, Mike NF4L
Re: New to RUMPed
Yes, it's the same file.Does it use the same format DXCC.rsd file as RUMLog? Since my file for RUMLog is more up to date, can I just copy it to the RUMPed folder
There is a Keyboard mode provided: Menu-->TRCVR-->Keyboard ModeIs there a place (or could one be added) to type in text to send if something isn't in a macro?
Use the RTTY menu for PTT. While you are in the keyboard mode, you can start typing, but you have to select Menu-->RTTY-->Transmit first to start the transmission.
