RUMlogNG 3.4.2 crashing with OS 10.12.5
Ever since the latest update to RUMlogNG, the program crashes within minutes of opening. Anyone else having this issue?
Re: RUMlogNG 3.4.2 crashing with OS 10.12.5
It has happened to me just a couple of times...
Nando
9Q6BB
Nando
9Q6BB
I haven't got any Crash reports from a 3.4.2 version. Please consider to send it after a crash.
You can find the report in the Console, I need the full crash log. Just drag and drop the file. The copied text only is nearly useless.
There is one known problem in 3.4.2: RL crashes when you
- have a band map open
- you are on 60m
- you have not set the edges for the 60m band in the Preferences under the QRGs tab
- you made other changes under the QRG tab recently
Version 3.7.1 fixed the issue. Working perfectly now!
