Autolog Fldigi to RUMlogNG v3.4
K3DCW
Unread post by K3DCW »
All,
For those of you using RUMlogNG and Fldigi, Tom has made a couple of changes to RUMlogNG v3.4 which support the use of an auto-import feature for Fldigi QSOs saved in Fldigi, without the need to use a macro button.
Directions and a link to the required file is included in the FAQ, and you can feel free to email me if you have any questions.
One note: This options uses the LanchAgents system in macOS to monitor the Fldigi temp log file for new QSOs. Anytime a QSO is saved, it imports the QSO then erases the temp log file so that it will be ready for the next time a QSO is saved. This will run forever until you uninstall it. So, if there are Fldigi QSOs you don't want saved to RUMlogNG, this script setup is NOT for you. However, if you want every Fldigi QSO you make saved to RUMlogNG, then this is your tool.
Enjoy, and thanks Tom for making the required changes.
Dave
K3DCW
cwpowell
Re: Autolog Fldigi to RUMlogNG v3.4
Unread post by cwpowell »
Not to appear dense, but where is the FAQ?
Chas - NK8O
In RUMlog see Menu-->Help-->RUMlogNG Help or here: http://dl2rum.de/RUMlogNG/docs/en/pages/FAQ.html
