New LoTW band confirmations no longer show as "new ones".
k4zrj
Unread post by k4zrj »
Runnig 3.2. When I get LoTW QSLs, new band confirmations no longer show in the "New one?" column and the "DXCC Entities" window does not get updated until I run a "Recalculate DXCC for all QSOs". In fact, the "New one?" column used to show "Band", "DXCC", "IOTA" and maybe a few others. Now, nothing shows in that column.
Also, have noticed in the "DX Spots" window, when I select a band the column "Hdg." is listed twice.
I really like the "Contest" mode. It works well for me. Is there a way to import contest QSOs into the log without going through the proces exporting and importing an ADIF file?
Thanks & 73,
Charles, K4ZRJ
Re: New LoTW band confirmations no longer show as "new ones"
Maybe these aren't new ones? Please note, the DXCC table isn't a real time window. You have to close and reopen it to update.
Which OS-X version are you using? I've seen this problem before. Go to the Terminal and enter:
defaults read de.dl2rum.RUMlogNG "NSTableView Supports v2 T_Dx_Spot"
What ist the result?
Menu–>Logbook–>Import contest file
k4zrj
Actually, the "new ones" are truely new ones. I worked three new ones in the 160M contest this last weekend and the LoTW QSLs came through but not shown as "new ones" and I had to recalulate DXCC before the DXCC window would reflect the new QSLs. I understand the DXCC window is not real time.
Running OSX 10.11.6. Terminal reply is : The domain/default pair of (/Users/charlesjohnson/Library/Containers/de.dl2rum.RUMlogNG/Data/Library/Preferences/de.dl2rum.RUMlogNG, NSTableView Supports v2 T_Dx_Spot) does not exist
Sorry, I did not see the menu entry "Import contest file".
73, Charles, K4ZRJ
k4zrj
The option Preferences -> LoTW/eQSL -> "Use QSL details" controls this behavior. For some unknown (?) reason, mine had become unchecked, resulting in the above "issue". Checked the box, and all is well once again.
73, CJ, K4ZRJ
