Increase/decrease CW speed
EA1DAV
Unread post by EA1DAV »
After this weekend of CQWW cw contest, my first with rumlog, i note that the cw send to my IC7300 don't vary the speed if i insert the comand in the memory.
I use the CAT for cw so messages are in comands and not in the RTS or CTR. The <wpm+x> or <wpm-x> has no efect in the transmited cw speed.
Also when the log increase the size by the contacts the call check function slow a bit the cw transmited.
Regards
Re: Increase/decrease CW speed
The Icom internal CW keyer doesn't support these speed changes. This feature is included in the Elecraft- and K1EL WinKeyers only.
