Automatic QRZ.COM lookup
Posted: Wed 9. Nov 2016, 16:11
I am using RumLogNG 2.14 and after I enter a call in the "Callsign" field and tab to the next entry field I expected that the QSO data from my QRZ.COM subscription would populate the remaining fields. It does not do this but after I have saved the log entry and highlighted it in the log window and then select the Add QSO Data pulldown and then choose use QRZ.COM I can over Overwrite the Existing Data with that from QRZ.COM.
I must have missed a configuration option somewhere but I can not find it. What do I need to check to ensure that the QSO data is retrieved from QRZ.COM and entered prior to having saved the new log entry?
Very 73 - Mike - K9JRI
