Grayline Map
Posted: Sat 1. Oct 2016, 04:14
by aa4ga
Hi All,
I tried doing a COMMAND-G to bring up the Grayline map, and NG crashed. Tried again via Window>Grayline and same thing.
I rebooted the computer, running only NG, and the Grayline map still crashes the program.
This is withe 2.13 - I just upgraded a night or two ago, and this may be the first time I've tried to access the grayling map since then, but not sure.
OSX 10.9.5
Any ideas?
73 de Lee
Re: Grayline Map
Posted: Sat 1. Oct 2016, 09:03
It seems there is an internal bug in a macOS framework. A very similar problem is listed in the "Known bugs" list in Apples Xcode documentation. I've filed a bug report to make sure.
All 10.9 users are affected, when the application was compiled using 10.12.
I can't offer a solution yet.
Re: Grayline Map
Posted: Sat 1. Oct 2016, 11:58
by aa4ga
Thanks Tom.
Is that new with this latest version of NG? I was able to use the Grayline map in the previous version.
Can I get the prior version of NG? If so, will that mean that Apple Maps won't work? Perhaps it would just be best for me to run another Grayline map.
I really can't upgrade past Mavericks unfortunately, because of all the other software upgrades I would have to do....Ugh.
73 de Lee
Re: Grayline Map
Posted: Sat 1. Oct 2016, 13:12
For the news in 2.13 see here:
http://dl2rum.de/forum/viewtopic.php?f=10&t=911#p3967
When you have a backup, you can reinstall your 2.12 version. Otherwise I can provide it, but you will lose the Maps.
Re: Grayline Map
Posted: Sat 1. Oct 2016, 21:48
by ct1drb
Hello all,
just to tell that I do not have problems with the Grayline Map and even the needle is visible.
Mac Mini 4gb running Mac OS Sierra, RUMlogNG 2.13. I am qrv for any question.
Best 73.
CT1DRB
David Quental
Re: Grayline Map
Posted: Wed 5. Oct 2016, 01:59
by aa4ga
Thanks Tom,
I restored 2.12 from Time Machine - do I just move the .app to the Applications folder?
Thanks!
Lee
Re: Grayline Map
Posted: Wed 5. Oct 2016, 08:05
I would rename it before moving to the Application folder. This prevents another unwanted update.
I've just got the confirmation from Apple that this is a bug. It will hopefully fixed soon.
Re: Grayline Map
Posted: Fri 7. Oct 2016, 13:56
by Cornel
Hi
RUMlogNG Version 2.13.1 (125) on a MBPro OSX 10.10.5.
Everything works fine, map and grayline map no problem.
In 2.1x i couldn't see the map, now it's all right.
Tnx Tom.
