Cat Cable for Yaesu Ft-450D with RumlogNG?
Posted: Tue 9. Aug 2016, 13:40
by K9afb
Is there a certain CAT cable I must buy to be able to work with Yaesu FT450d and rumlogng on Mac? or is this not possible?
Re: Cat Cable for Yaesu Ft-450D with RumlogNG?
Posted: Fri 12. Aug 2016, 05:22
by KO4JY
Just a shot in the dark here but this is a USB cat cable for your rig. I'm betting it would work.
https://www.amazon.com/Ft-450-Ft-2000-F ... +cat+cable
KO4JY
Posted: Fri 12. Aug 2016, 13:22
by K9afb
thanks for the suggestion, upon research I found out that cable will not work on a MAC OS X because of the drivers, they are prolific, where as we need FTDI Chipset..that same Cable is listed on Ebay and they mention that in their details of this cable.
Posted: Fri 12. Aug 2016, 13:25
The latest Prolific divers work fine under macOS: http://www.prolific.com.tw/US/ShowProdu ... 29&pcid=41
Assuming an original Prolific chip is used.
Posted: Fri 12. Aug 2016, 13:42
by K9afb
Thats the thing Original, most seem to be from China..and that cable with the same numbers on it LD-C102..was from China Post.. so probably not original I would assume..
Like this cable same numbers on it, but in Description is says will not work on MAC OS..
http://www.ebay.com/itm/USB-to-RS232-Se ... SwDk5T~Diy
Posted: Sat 13. Aug 2016, 03:07
by KO4JY
I just did some reading on the Cat interface of the FT-450. It's a standard RS232. You can use any number of regular USB to RS232 cables. I've purchased them as cheaply as $10US on Amazon. You don't need anything special for this radio.
Kevin
73 de KO4JY
Posted: Sat 13. Aug 2016, 13:28
by K9afb
it's not the problem with the Cable it's if the chipset runs a certain type of Driver, and I did run into that on my Imac imitation prolific chipset will not work on a MAC..
Posted: Sat 13. Aug 2016, 14:59
by KO4JY
I worked for Cisco Systems for many years. Over the years I have purchased many USB to Serial adapters that work with Macs. Here is one for under $10 that I know works with a Mac. It's even listed as Mac Compatible. I think you are over analyzing this.
Posted: Sat 13. Aug 2016, 15:03
by KO4JY
This one is actually recommended by the Prolific website as being an original and it's $14.95.
http://plugable.com/products/PL2303-DB9/
Posted: Sat 13. Aug 2016, 16:53
by K9afb
I am merely stating what I read and numbers off of the cable that was referred to before..that one clearly stated on the amazon and Ebay sites as does not work with MAC OS X..
so I do not get how you say "I am over analyzing"
I never said there where not others, now you brought in 2 different cables that were not even talked about before. So those might work that you mention, but that does not mean I am over analyzing? I never said no cable worked, i said the one that was mentioned at first was listed as non OS X...
I found a Cable that has the FTDI Chipset and am sticking with that as it is known to work with my Radio FT-450D as the reviews mention that it did for others, I just don't want to waste my time getting a cable that might not work so i researched and went by what I read, Reviews, and Claims of not working on MAC OS X, I do not think that is over analyzing things...lol .
