Hamlib configuration
Posted: Sun 29. May 2016, 04:48
I'm trying to setup hamlib on my mini since I want to share data among many programs (fldigi, RUMlogNG, wsjt-x, etc). I have hamlib installed via ports, version 1.2.12, and it talks to my TS-2000 fine. I was then able to configure other programs to use hamlib, and they were able to control the radio as well as get data from it easily. However, I seem to be unable to get RUMlogNG to speak to the radio.
I've left my old settings as they were (which worked fine controlling the rig) and changed interface to TCP, adding 127.0.0.1 to the host and port 4532. The program lights up the kHz and mode in green, showing that it has a connection, and if I have hamlib in trace mode I see a connection open to the program but no data is exchanged over the socket. I can of course make this work by keeping fldigi running all the time, and using that as the link (via xml-rpc) between RUMlogNG and hamlib, but I'd rather not have to keep an extra program open (which seems to crash a bit on me as well) if I don't have to.
Am I missing a setting somewhere, or does the TCP interface not mean what I thought it did? Thanks!
