Pseudo FSK
Pseudo FSK
Hi, how to run pseudo FSK with FLDigi and RUMLogNG ? Still not able to run it after various tests.
AFSK is working well with no problem.
Any solutions ?
Thanks de IV3TMM.
Any solutions ?
Thanks de IV3TMM.
Ciao de Francesco
IV3TMM
IV3TMM
Re: Pseudo FSK
I use a microHAM digiKeyerII, works fine for pseudo FSK. What interface do you use?
Re: Pseudo FSK
TNX Tom, yes me too, i use DigiKeyer II by Microham.
Could you help me ?
I can send you pictures of my settings.
Ciao.
IV3TMM.
Could you help me ?
Ciao.
IV3TMM.
Ciao de Francesco
IV3TMM
IV3TMM
Re: Pseudo FSK
To help you, we need to see your Fldigi and microHAM settings Find attached my settings. Make sure you are using the same sample rates for the sound card in- and output.
Re: Pseudo FSK
TNX Tom, but it' s not running.
Everything is working PTT and modulation but i listen only DIDIDIDIDIDI in monitor mode during the transmission in RTTY mode.
If i change on SSB mode i listen the right RTTY modulation.
Seems that FLDIGI still transmit on AFSK even if i selected Pseudo FSK.
Ciao de Francesco
IV3TMM
IV3TMM
Re: Pseudo FSK
AFSK may be still present on the left channel. Is the FSK LED flickering on the DKII? Is the DKII in FSK mode?
Re: Pseudo FSK
Yes the FSK LED is flickering when transmitting.
How to check if the DGKII is in FSK mode ?
I miss, .... when i send Memory 3 saved in DGKII with RYRYRY with RumLogNG, everything is fine.
Ciao de Francesco
IV3TMM
IV3TMM
Re: Pseudo FSK
To see the DKII mode, open the microHAM window: Menü-->Window-->microHAM
When the FSK is flickering, it looks good.
Re: Pseudo FSK
Yes, all is OK, but FSK is orange color, that' s right ?
See picture-
TY.
See picture-
TY.
- Attachments
- IV3TMM_1.tiff (1.22 MiB) Viewed 9336 times
Ciao de Francesco
IV3TMM
IV3TMM
