Newbie Questions
Posted: Tue 16. Feb 2016, 16:58
by wb2pkr
I installed RUMlogNG about a week ago and I have been using it without any major problems. However, I have not been able to figure out a few things...
I cant seem to get the auto-connect feature to work in the Terminal mode for the VE7CC cluster. Auto-connect works fine for other clusters e.g. W3LPL, K3LR, DXUSA.
In order to get the VE7CC cluster to connect, I must manually enter my callsign. Known issue/bug? or am I perhaps missing something?
I use multiple monitors, but RUMlogNG seems to only know of one monitor. While I am able to use both monitors with RUMlogNG, when I quit and go back into RUMlogNG, it doesnt remember the screen layout and as such, it puts all the various RUMlogNG windows into a single monitor. Is there some way to save my two monitor layout?
I use the CW Tools window and I poll from TRX (Elecraft K3). Is there some way to clear the polling window?
In the DXCC window there is a dropdown to select Paper and/or LOTW. What about eQSL? Id like to be able to include those QSOs in my totals. I dont really care that the ARRL wont accept eQSL QSLs for DXCC Credit. I like to keep score of ALL my Qs from ALL sources. There doesnt seem to be a window or option to include all Qs in my log to summarize DXCC entities worked. Am I missing something?
73, Ron WB2PKR
P.S. Thanks Tom, the new version (NG) is great! I was able to migrate from DxLab without a hitch and finally retire the last Windoze machine in the shack.
Re: Newbie Questions
Posted: Tue 16. Feb 2016, 17:25
Auto connects fine here, do you have set your user name for this cluster in the preferences?
Some adjustments in the System Preferences settings are required:
Mission Control.tiff
Mission Control.tiff (1.1 MiB) Viewed 9430 times
Further more you have to right click the RUMlog Icon in the Dock and select the Options menu and choose: „Assign to this space“ (Not sure about the english wording)
Menu-->Logbook-->Clear while this window has the focus
What about eQSL?
Just the numbers of your eQSL confirmations are available:
eQSL.tiff
eQSL.tiff (113.83 KiB) Viewed 9430 times
eQSL.tiff
Posted: Tue 16. Feb 2016, 17:45
by wb2pkr
Yes, strange. I've tried it both ways: specifying my call in the preferences as well as clearing it and using the default. Neither work for VE7CC only. Works for all the others. Oh well. I will just live with it for now.
Multiple Monitor Layout Saved. Cool. I wasnt aware of that feature in Mission Control. In fact, I've never used Mission Control. Thx.
Yeah, I saw that , but you cant just add those totals to the other totals. Would be nice to have a grand total for all QSL sources.
Perhaps you might consider this as a future requirement/feature.
Thanks for the timely response.
Hope to catch you on the bands. 73, Ron WB2PKR
Posted: Tue 16. Feb 2016, 18:05
Can you post the content of the terminal window for VE7CC?
Posted: Tue 16. Feb 2016, 18:37
by wb2pkr
Here is a screenshot of my preferences for the terminal connections as well as the terminal window.
As you can see, the VE7CC is waiting for me to type in my callsign. If I dont type in my callsign, eventually it times out and disconnects.
This doesnt happen with W3LPL and K3LR. As you can see, they are both logged in.
Posted: Tue 16. Feb 2016, 23:31
by K3DCW
Try changing your call sign to all upper case. I recall at least one Cluster site that didn't like lower case, but would take all upper case. I don't remember which one that was, but once I changed it then autoconnect would work.
Dave
K3DCW
Posted: Wed 17. Feb 2016, 13:48
by wb2pkr
Good idea Dave. However, as you can see in the attached screenshot, no luck.
However, this morning I decided to add another source to the DX Cluster Preferences.
As you can see, VTEST, which is also VE7CC, auto connects.
Very strange. I subsequently moved the VTEST to the first location in the list and it did NOT auto connect.
I moved it to the other locations (2nd,3rd location) and it connected. There must be something about it being the first one in the list.
Followup question: In the DX Spots window, is there a way to determine what cluster source a particular spot came from?
Posted: Wed 17. Feb 2016, 14:28
I tried a lot of combinations. I'm not able to duplicate the problem. :-(
No.
Posted: Sat 21. Oct 2017, 23:27
by k6wru
No.[/quote]
That would be a handy feature, to have an optional column for the DX cluster name.
Right now, I'm getting spots from DX, SOTA, and JOTA clusters, but I have no idea which ones are for JOTA (Scoutings Jamboree on the Air).
wunder
