Editing Problem
Posted: Sat 13. Feb 2016, 21:07
by aa4ga
I can no longer edit a single QSO...either that or I've forgotten how.
If I select a QSO, then either double-click it, OPTION-CMD-E, or use the menu to QSO>EDIT QSOs, the only thing that happens is that the Main Logging window turns transparent. There is not a drop-down form. Also, I cannot return the Main Logging window to its normal appearance without restarting RUMlogNG.
The odd thing is, if I select multiple QSOs, and use any of the methods listed above to edit, the edit drop-down appears and I can successfully edit multiple QSOs.
Am I missing something in how this works, or do I have a problem?
Earlier today I updated Java to Ver. 8 / 73 and thought the problem might be related to that, but I subsequently uninstalled Java and have the same problem in RUMlogNG. I have reinstalled the most recent version of Java now. I'm running Mavericks. RUMlogNG 2.5.2(94).
Thanks!
Re: Editing Problem
Posted: Sat 13. Feb 2016, 22:32
Can you e-mail your log file please? I want to check no idea yet.
Re: Editing Problem
Posted: Sat 13. Feb 2016, 22:59
by aa4ga
Email is on the way - thanks!
Re: Editing Problem
Posted: Wed 17. Feb 2016, 15:27
by aa4ga
Thanks to Tom for the super support - through some back-and-forth, it looks like the problem is now fixed!
73 de Lee
