eQSL certificate problem
Hi Tom.
Since Saturday I'm having a problem with the eQSL site certificate.
When I try to download new eQSLs, RUMLogNG says:
"The certificate is not valid" and so on.
(Original auf Deutsch: "Das Zertifikat für diesen Server ist ungültig. Möglicherweise werden Sie mit einem Server verbunden, der vorgibt. "www.eqsl.cc" zu sein, und Ihre vertraulichen Daten gefährdet.")
What's going on? Is it possible to bypass the certificate mismatch?
73 de IZ1TGH
73 de IZ1TGH
Re: eQSL certificate problem
You have to ask eQSL for a solution. RUMlog uses a secured https connection whenever it is possible. eQSL broke this now due to a expired certificate.
my solutiom at moment....
close Safari
restart safari and go to https://www.eqsl.cc
click on show certificate on this popup
authorizes the certificate manually
Have fun with RUMlog
close Safari
Siegfried, OE1HXS got this answer from eQSL:
Hi
For now do not use https://www.eqsl.cc, instead use http://www.eqsl.cc.
The webmaster is aware and the renewal process is under way73,
M0TNG
Support Volunteer
I also fixed the problem by going to Safari to the secure URL (https://www.eqsl.cc) ... When the security certificate dialog was presented, I clicked for details and proceeded to select "trust always" instead of "use system defaults"... Then reload the page and quit Safari ... Go back to RUMlogNG, and you'll be fine. -- Randy K7RAN
I can use http://www.eqsl.cc in my browser (default browser is Chrome) but How do I tell RumLogNG to use that address when it connects for an upload? And related to this, I have not been able to figure out how to list eQSL as a "trusted" site in Chrome.
You have to use a SSL connection: https://eqsl.cc/
Sorry, but I don't understand the solution.
I use Chrome, I try the solution opening Safari, not problem to see the web but with rumlogNG 2.5 not working
Toni EA2CXK
Toni EA2CXK
Even in Chrome you see the error. You have to use a SSL connection: https://eqsl.cc/
