Page 1 of 2
eQSL certificate problem
Posted: Mon 25. Jan 2016, 23:15
by IZ1TGH
Hi Tom.
Since Saturday I'm having a problem with the eQSL site certificate.
When I try to download new eQSLs, RUMLogNG says:
"The certificate is not valid" and so on.
(Original auf Deutsch: "Das Zertifikat für diesen Server ist ungültig. Möglicherweise werden Sie mit einem Server verbunden, der vorgibt. "
www.eqsl.cc" zu sein, und Ihre vertraulichen Daten gefährdet.")
What's going on? Is it possible to bypass the certificate mismatch?
73 de IZ1TGH
Re: eQSL certificate problem
Posted: Mon 25. Jan 2016, 23:24
You have to ask eQSL for a solution. RUMlog uses a secured https connection whenever it is possible. eQSL broke this now due to a expired certificate.
Posted: Tue 26. Jan 2016, 08:52
by IS0FFD
Hi to all!
I've the same problem...
RUMlogNG version 2.5.1 and OS 10.10.5
screenshot
Who has a solution??????
73 de ISØFFD Maurizio
Posted: Tue 26. Jan 2016, 09:31
by IS0FFD
my solutiom at moment....
close Safari
restart safari and go to
https://www.eqsl.cc
click on show certificate on this popup
authorizes the certificate manually
Have fun with RUMlog
Posted: Tue 26. Jan 2016, 10:49
Siegfried, OE1HXS got this answer from eQSL:
Posted: Tue 26. Jan 2016, 16:09
by K7RAN
I also fixed the problem by going to Safari to the secure URL (
https://www.eqsl.cc) ... When the security certificate dialog was presented, I clicked for details and proceeded to select "trust always" instead of "use system defaults"... Then reload the page and quit Safari ... Go back to RUMlogNG, and you'll be fine. -- Randy K7RAN
Posted: Wed 27. Jan 2016, 11:17
by N8XMS
I can use
http://www.eqsl.cc in my browser (default browser is Chrome) but How do I tell RumLogNG to use that address when it connects for an upload? And related to this, I have not been able to figure out how to list eQSL as a "trusted" site in Chrome.
Posted: Wed 27. Jan 2016, 14:18
You have to use a SSL connection:
https://eqsl.cc/
Posted: Sun 31. Jan 2016, 12:48
by ea2cxk
Sorry, but I don't understand the solution.
I use Chrome, I try the solution opening Safari, not problem to see the web but with rumlogNG 2.5 not working
Toni EA2CXK
Posted: Sun 31. Jan 2016, 13:20
Even in Chrome you see the error. You have to use a SSL connection:
https://eqsl.cc/
