Kenwood TS-50
Posted: Sat 26. Dec 2015, 19:10
by ea2cxk
Hi all,
I own a old Kenwood TS-50, I used it with Fldigi without problem with CAT interface, but with RumloNG and old versions I couldn't use.
It is possible in a future to put this rig? the commands are the following:
Full duplex serial, 4800 Baud, 1 start, 8 data, 2 stop bits No parity
Commands consist of a 2-char command, parameters, and a semicolon terminator
Error messages:
?; - Syntax error or radio in wrong mode
E; - Communications error
O; - Processing not complete
FA00007000000;     Set VFO A to 7 MHz.  Freqs are 11 digits, in Hz
FA;                Read VFO A
FB00007000000;     Set VFO B to 7 MHz.  Freqs are 11 digits, in Hz
FB;                Read VFO B
FNx;               Select VFO A (x=0), VFB B (x=1) or MR (x=2)
ID;                Read radio ID - TS-50 is 013
IF;                Read info from radio - answer is
  IFaaaaaaaaaaa     bbbbbc  ddefghijkk ;
     a: 11 digits of frequnecy.  b: RIT offset in Hz - first char is + or -.
     c: 0-rit off, 1-rit on  d: memory channel.  e: 0-rx, 1-tx  f:
mode
     g: 0-VFO A, 1-VFO B, 2-MR,  h:scan off/on  i: split off/on  j:
tone off/on
     k: ctcss frequency
        CTCSS: 38 standard tones numbered 01 (67.0) - 38 (250.3) or 39 (1750Hz)
MDm;              Set mode to m
    mode: 1 - lsb, 2 - usb, 3 - cw, 4 - fm, 5 - am
TX;               Transmit
RX;               Receive
SPa;              Split off (a=0) or on (a=1)
Thanks for advance
Toni EA2CXK
Re: Kenwood TS-50
Posted: Sat 26. Dec 2015, 19:52
Select any Kenwood, it should work.
Re: Kenwood TS-50
Posted: Mon 28. Dec 2015, 08:21
by ea2cxk
Nice!!! it works with Ts-480.
I don't know why I don't try before.
Thanks a lot of Toni EA2CXK
