Is any body using Digimaster Pro 3? I'm looking some advice how to configure Winkeyer! http://www.g4zlp.co.uk/unified/DigiMaster_ProThree.htm
Regards, Kes. m0pkz
Digimaster Pro 3
Re: Digimaster Pro 3
So far I can see from the site, you will find 3 new com ports when the interface is plugged in.
What is your problem exactly?
Sorted now
it's working!!! Thank you Tom!
I hope the Winkeyer works. I've just ordered the CW keyed from this site. I like the slime design.
Yes it's works. Only the thing Tom, can't get FLDIGI send CW. FLDIGI seems didn't got winkeyer option.
Regards, Kes.
Regards, Kes.
You can have RumlogNG send CW and use FLDigi as your skimmer. the only trick is to make sure rumlogng has focus and not fldigi.
Hope this helps.
Hope this helps.
Kes,
I got my G4ZLP cw keyer yesterday and have had some problems. Speed setting and returning the control to the speed pot works slightly in a different way. I have added an option to select which "Winker" is used: K1EL, K3NG or G4ZLP.
