ts-480SAt and cat
Posted: Wed 4. Nov 2015, 18:32
by m0pkz
Maybe some body can help?
first time setting works fine with my ts-480sat and rumlogng, but after relaunch need go on the meny Transceiver and press Reet CAT 1....
The thing is...after closing software it beeps like disconecting...but on the transceiver screen still shows PC (like connected).
Other programms works fine...like fldigi....macloggerdx....
Any ideas?
Regards, Kes. m0pkz/ly3k
Re: ts-480SAt and cat
Posted: Wed 4. Nov 2015, 18:38
Please post a screen shot of your TRX settings.
Posted: Thu 5. Nov 2015, 18:10
by m0pkz
Her we are! :) tried different settings...only after restart ...reset cat helps!
Posted: Thu 5. Nov 2015, 18:19
When you reset the CAT via menu it works after that?
Posted: Fri 6. Nov 2015, 08:49
by m0pkz
Yes.
Also tried few different settings...different kenwood radios...same issue....
But as I said...other programs didn't got this issue....
The interface which I'm using: http://www.g4zlp.co.uk/unified/DigiMaster_ProThree.htm
FTDi chipset.
Regards, Kes.
Posted: Fri 6. Nov 2015, 09:10
Once again my question: When you reset the CAT via menu it works after that?
Posted: Fri 6. Nov 2015, 09:57
by m0pkz
YES Tom!
Posted: Fri 6. Nov 2015, 10:03
Okay, this was not very clear for me.
Version 2.2 fixes a bug with exact this problem. Please download it from here:http://dl2rum.de/RUMlogNG/RUMlogNG.zip
Please check it it helps you. This version is awaiting Apples Review process and is not available in the store yet.
Posted: Fri 6. Nov 2015, 10:18
by m0pkz
Got it Tom. I've downloaded from app store so here is the prob!
Thank you for update! Will download zip file tonight!
Regards, Kes.
