Wrong frequency shown in log window
Posted: Wed 28. Oct 2015, 08:41
by dg3yjb
when I startup RUMlog the frequency in the log window is set wrong. As you see in the screenshot the frequency is is set to the frequency of the last QSO and follows not to the settings done at the trx, even if the checkbox "Folge TRX" is checked or not. The frequency in the band map and the trx control is correct shown. The trx is powered up first and then I started RUMlogNG. After the Reset of CAT #1 the frequency in the log window shows the correct value and follows to the trx settings.
My setup is a Elecraft KX3, RUMlogNG 2.1 an MAC OS OX 10.11.1 (El Capitan).
vy 73 de Jan (DG3YJB)
