Transceiver menu
Posted: Fri 11. Sep 2015, 22:16
by NF4L
Tom -
When I look at the "Transceiver" item on the menu bar, only "Reset CAT" and "Abort Transmission" are active (not greyed out). What am I doing wrong?
73, Mike NF4L
Re: Transceiver menu
Posted: Fri 11. Sep 2015, 22:58
What do you expect to see?
Others are active, pending on your configuration.
Posted: Sat 12. Sep 2015, 07:59
by NF4L
I expect to see them all enabled :D . I looked thru preferences and Help, and didn't see anything about enabling the K3 P3 control screens. In CW preferences, Transceiver is selected as the CW interface. CAT works FB.
73, Mike NF4L
Posted: Sat 12. Sep 2015, 09:00
Ahh, I was not aware of your setup.
The K3 and P3 menu items become available when you select the "K3 Ctrl" in your TRX preferences.
The "Edit CW memory" item is for Icom and Yaesu transceivers only. Elecracft don't like to tell me, how to do this. There is no documented interface available.
Posted: Sat 12. Sep 2015, 10:17
by NF4L
Thanks, Tom - I knew I had seen the control screens before. Too bad about the internal CW memories. A note about these would make a nice addition to the Help file... :o
73, Mike NF4L
Posted: Fri 9. Oct 2015, 13:02
by k2np
Thanks. I came here to ask this very question! What is the value of the K3 (without the CTRL) setting for the TRX if you can't actually control the transceiver?
Posted: Fri 9. Oct 2015, 13:43
Using the simple K3 setting, you can exchange frequency and mode only. The same functions, as for other supported devices.
When you select the "-Ctrl" option, you have more controls for the K3 and P3. See the attached screen shots to get an idea.
K3.tiff
K3.tiff (152.95 KiB) Viewed 6784 times
K3.tiff
P3.tiff
P3.tiff (115.38 KiB) Viewed 6784 times
P3.tiff
