QSO data exchange possibilities
Posted: Fri 3. Jul 2015, 12:37
See the attached document for log file and ADIF data exchange between RUMlog on your Mac and iDevice.
Data Exchange.pdf
(46.9 KiB) Downloaded 4903 times
Data Exchange.pdf
Re: QSO data exchange possibilities
Posted: Sun 28. Aug 2022, 21:34
by K1JX
I'm having bad luck with this with the most recent update.
Normally, I use a MacBook Air M1 for all the logging. I then routinely save the latest log file to iCloud for backup. I do this through normal macOS means, not directly through RumLogNG.
I often download a copy of this log directly to RumLog2Go on my iPad Pro so that if I see a spot while doing something else, I can see if I'd already worked the station. Then I'd head to the shack.
This approach has worked for years, very successfully.
But, since updating to 6.0 August 2022 this no longer works. If I try to "Download log" from Log Settings, it looks like the log is being downloaded, but it doesn't appear in the window of logs as being available. If I copy a log file to my iPad and try to open it, same thing.
I have another iPad Pro that I haven't updated RumLog2Go on. It's still at 5.4.7 July 2022. It still works perfectly.
I tried deleting and reinstalling 6.0, with the iPad powered off after deleting 6.0. No effect.
Bug? Error by me? Note that I'm not doing anything with Syncing Logs.
Posted: Wed 7. Sep 2022, 10:43
There is a problem in the latest version, I can confirm that. I'm not sure, but it seems I published an older version, not ready for release. I will send you a TestFlight invitation to make sure.
Posted: Tue 21. Mar 2023, 19:33
by DL5KCI
Hello Tom,
i would like to exchange new records from my iPad (rumlog2go) with my MacBook (rumlogNG). I marked single records (QSOs) i want to bring there but rumlog2go tells me to upload all records. Is this only possible via ADIF-File exchange?
73, Ingo
Posted: Tue 21. Mar 2023, 20:06
You have to mark the QSOs in question using the QSO contextual menu before you start the export routine.
Posted: Thu 30. Mar 2023, 19:19
by f5ukw
DL2RUM wrote: ↑Tue 21. Mar 2023, 20:06 You have to mark the QSOs in question using the QSO contextual menu before you start the export routine.
What do you mean "mark the QSO in question"?
Posted: Fri 7. Apr 2023, 19:21
by DL5KCI
i 've marked the QSO: for example 10 qsos of 20 qsos and choose "Export to synced log". But the popup tells me: " all QSOs from this log will be imported in synced log"
What am i doing wrong ?
73, Ingo
Posted: Fri 7. Apr 2023, 21:39
You can't export single QSOs into the synced logbook. In the synced logbook you can import single QSOs via ADIF.
Posted: Sun 9. Apr 2023, 11:29
by DL5KCI
works, mni tnx!
