Contest Definition Files, Contest Maker
ua4fqi
Re: Contest Definition Files, Contest Maker
Unread post by ua4fqi »
DL2RUM wrote:You can only add a note to the QSO, not very user friendly. It seems i have to more modes. But no spare time yet .....
If you have free time, correct for the following contest.
Thank you for your support.
73!
ua4fqi
I very much liked to work in contest on your program. If you have time, ask to add Open UKRAINE RTTY Championship
http://uarl.com.ua/openrtty/2012/rtty2012e.txt
Thankful in advance!
The idea behind the plugin concept is, the user can create own contest templates. Please try it yourself using the ContestMaker tool. There are a lot of examples provided.
Scandinavian Activity Contest - SAC
SAC Scandinavian-side.plist
(11.09 KiB) Downloaded 1102 times
SAC Eu-side.plist
(8.22 KiB) Downloaded 995 times
SAC Eu-side.plist
SAC dx-side.plist
(7.86 KiB) Downloaded 983 times
SAC dx-side.plist
OQRP
http://www.qrpcc.de/contestrules/oqrpr.html
OQRP.plist
(8.12 KiB) Downloaded 912 times
OQRP.plist
NRAU-Baltic-Contest
NRAU-Baltic.plist
(23.04 KiB) Downloaded 868 times
NRAU-Baltic.plist
DL-DX-RTTY Contest
DL-DX_RTTY_DL-side.plist
For German Stations only
(8 KiB) Downloaded 855 times
DL-DX RTTY dx-side.plist
All stations outside Europe use this plugin
(8 KiB) Downloaded 831 times
DL-DX RTTY Eu-side.plist
For Europain stations only
(8 KiB) Downloaded 828 times
kf5jra
Unread post by kf5jra »
Colorado QSO Party
Since I live in Colorado and I noticed that there is not a file for the Colorado QSO party I thought I would give it a try. It is far from being complete which is why I am posting it here along with the link to the documentation for last years contest. My first stumbling block is the RX strings. For the COQP it is Name and State (2 boxes) The second is the different points for modes and categories.
Here is the link for the rules:
http://ppraa.org/downloads/coqp/2013%20 ... 2013-1.pdf
Thank you in advance.
Colorado QSO Party.plist
(14.68 KiB) Downloaded 804 times
Re: Colorado QSO Party
I sent you a p-mail
G4FSU
Unread post by G4FSU »
One point I've noticed on RTTY with the K3 is that the K3 internal RTTY decoder is often better than cocoamodem. I find I am reading the received info off the K3 display and not the RX window on RUMped.
Would it be possible to have the K3 internal modem as an option for both TX and RX within RUMped? This is available on RUMlog, but not for contests! PSK31 TX/RX on the internal modem would be good also - especially if PSK63 is added to the K3 which has been discussed on the Elecraft reflector.
Many thanks & 73,
Ian G4FSU
