DX Spots not updating "DX SPOTS"
Posted: Sun 19. Apr 2015, 16:15
by K6LE
Using App store version 1.1 (46).
I like the ability to click SH/DX on the Telnet window and have the DX SPOTS window updated. However, it seems that since 1.1 that is the only way DX SPOTS is updated.
If I watch spots come in in the Telnet window they usually don't appear in the DX SPOTS window until I click the SH/DX button.
BTW, speaking of the DX SPOTS window, will the country's name be included in a later release?
Re: DX Spots not updating "DX SPOTS"
Posted: Sun 19. Apr 2015, 17:02
This works fine here. Maybe the same like this: http://dl2rum.de/forum/viewtopic.php?f=10&t=642 ?
Posted: Sun 19. Apr 2015, 20:35
by K6LE
It seems the problem was cured by switching Telnet Clusters.
I was using N7TR - an AR cluster and switched to VE7CC - a CC cluster and now it is working fine.
Posted: Mon 20. Apr 2015, 00:23
by k4zrj
Also works with DXSpider from W1DX.
Posted: Tue 21. Apr 2015, 10:35
Thanks for pointing out this Rick. It will be fixed with the next update.
Posted: Tue 21. Apr 2015, 15:29
by K6LE
Thanks Tom.
Posted: Sat 25. Apr 2015, 16:44
by K6LE
K6LE wrote:Using App store version 1.1 (46).
Incidentally, I decided to start using "Spots" again as my Telnet client and have RUMlogNG connect to it so I would have better control over cluster filters. This also solved the country name problem!
There's a check box in Spot for country name and with it checked the name appears in the comments section. So, that concern is handled.
Posted: Sat 25. Apr 2015, 16:58
And I spend weeks of hard work to add this killer feature:
dx.tiff
dx.tiff (176.1 KiB) Viewed 9385 times
dx.tiff
My idea was to let this function active for few weeks. In this time you can memorize all prefixes-
Posted: Sat 25. Apr 2015, 17:34
by K6LE
Looks good.
That way I won't have to run "Spot" if I don't want to. :)
