LOTW flag setting
Posted: Wed 15. Apr 2015, 19:32
by g4sjp
Whenever I log a QSO, the LOTW flag is being automatically set to 'S'. This lead me to believe for a while that the QSO had already been uploaded to LOTW but I became suspicious that this was not the case and checked on the LOTW website, which showed that not to be true. I then clicked on LOTW out and the QSOs were uploaded with no problem. I have checked my settings and can find nothing wrong. I have no problem with manually sending QSO details to LOTW (in fact I would prefer to do that), but I would rather the LOTW flag remained on 'W' until such time as I force an upload. The same behaviour is apparent in the e-Q column.
I am using the latest version from the App Store.
73 Stephen
Re: LOTW flag setting
Posted: Wed 15. Apr 2015, 20:24
When you start RUMlogNG, the default values for QSL, LoTW and eQSL are the last logged values.
Before you log a QSO, set the fields as desired. Log the QSO and quit RUMlog. After the next start, you should see the new defaults.
When you log a QSO with status 'S', this QSO will not be uploaded! To force the upload, select the affected QSOs first and then use the QSL menu. Only the marked QSOs will be uploaded.
Posted: Wed 15. Apr 2015, 20:34
by g4sjp
Thanks Tom,
That seems to have solved the problem.
73 Stephen G4SJP
