Rotor control update
NF4L
Unread post by NF4L »
LRotor, a program for turning a rotor, gets heading information from RUMLogNG and classic RUMLog, using an Applescript application.
V2.0 of LRotor is now scriptable, it no longer uses GUI scripting. This should result in smoother, more reliable operation, with no configuration issues for users.
Thanks to Tom for making the logs scriptable, and for his assistance with scripting for LRotor.
More information and download at: http://nf4l.com/rotor/
73, Mike NF4L
73, Mike NF4L
m0pkz
Re: Rotor control update
Unread post by m0pkz »
Hi Mike,
Would be nice integrate the rotator control in to Rumlogng ....I mean do settings on Rumlogng and do not run as a separate app :)
But anyway thank you Mike for the great job!
wa2bfw
Unread post by wa2bfw »
Will RLog work with a DCU-2?
Marv wa2bfw
a45wg
Unread post by a45wg »
For those who want to roll their own Rotator control this is what I do...
To get the current station, I have modified and made much smaller the RumLonNG2LRotor to 2 lines of AppleScript.
If you want to get this from a bash prompt then the general way is like this
#!/bin/bash
heading=$(/usr/bin/osascript << EOT
tell application "RUMlogNG"
  return headingToCountry
end
EOT)
if [ $? -eq 0 ]
then
  echo "Heading is $heading"
else
  echo "No sure About the heading"
fi
You can then call as pass the heading as a parameter to whatever control program you want.
If (like me) you have your own Rotor Control program (in Python) - then this needs to work from Python.... So the code to get the heading is like this.
#!/usr/bin/python3
import subprocess
script = '''tell application "RUMlogNG"
  end tell
proc = subprocess.Popen(['osascript', '-'],
                        stdin=subprocess.PIPE,
                        stdout=subprocess.PIPE)
stdout_output = proc.communicate(script.encode('utf-8'))[0]
heading=int(stdout_output)
print(str.format('Heading is {}  Object Type is  {}',heading,type(proc)))
I hope that helps if anyone is trying to do this for themselves.
73s de Tim, A45WG
va2ss
Unread post by va2ss »
Hi guys,
I was looking to ask Mike NF4L a request on his LROTOR scripts he made.... but when searching in QRZ.com for his name.... It is indicated "Silent Key SK"!!
I am really sad to find this bad news today...... He done an excellent job to support rotor control with RUMlogNG.
What will be next now ??? I was looking a way to ask to add the support for the Green Heron RT-21 rotor controller.... Actually, it is working if I select "DCU-1" protocol. But I unfortunately I cannot see the actual rotor heading in the application window. But I can drive the rotor with the script, but without the actual direction displayed in the application window.
Any idea how I can resolve this??
Jeff | VA2SS
NF4L wrote:LRotor, a program for turning a rotor, gets heading information from RUMLogNG and classic RUMLog, using an Applescript application. V2.0 of LRotor is now scriptable, it no longer uses GUI scripting. This should result in smoother, more reliable operation, with no configuration issues for users. Thanks to Tom for making the logs scriptable, and for his assistance with scripting for LRotor.
73, Mike NF4L
m0pkz
also would so nice completely integrate in to Rumlogng.... :) full package :)
Louis ON5EN
Unread post by Louis ON5EN »
No reply from NF4L, email is bounced...
I was about to ask for more info on using a HyGain DCU-3x with RumLogNG :
My HamIV gave up after 36 years of good service and a new one is thus needed.
If I cannot obtain info very soon (winter is coming...) it wil be a HamIV with manual control...
No problem with that, but it was a good occasion to improve the station hi.
tnx for any news out of the group.
73 de Louis ON5EN
Mike, NF4L is sk.
