QRZ XML Data
W0DJC
QRZ XML Data
Unread post by W0DJC »
I noticed that when I put my own call into RUMlogNG, that the xml data for my image comes up as http://files.qrz.com/c/w0djc/DSC01869.jpg.
The correct url is http://files.qrz.com/c/w0djc/W0DJC.jpg
I wrote to QRZ, and they show that they are sending the correct url, and that I should contact you.
Below is the response I received from QRZ.
Hi Donald,
I have reviewed your account and looked at the XML data for your callsign, We are sending the correct URL - http://files.qrz.com/c/w0djc/W0DJC.jpg
Unfortunately you will need to contact the author of the software for more assistance.
Don
Re: QRZ XML Data
For a time ago I asked qrz.com for a temporary and free of charge test account. This was rejected. I have no possibility to test. I will check the docs again.
Is the picture seen in the lower window?
W0DJC
Re: QRZ XML Data
No image shows up in the lower window. If it helps, when I input other calls, some have images, some do not.
Re: QRZ XML Data
Thanks Don, failure found. It will be fixed in the next version.
