Clicking on DX in the DX Spot Window
Posted: Sun 22. Mar 2015, 15:20
by jweisskohl
I noticed that you need to double-click exactly on the frequency field in the DX Spot Window in order to automatically have the radio QSY to that frequency. Clicking anywhere else on that line just loads that station into the log in edit mode. RUMlog Classic allowed you to double-click anywhere on that line and it would change the frequency on the radio. This was a little confusing until I realized that this is the way it now works. Is there some reason or advantage having it now work this way?
When I open the DX Cluster window I am not able to populate the DX Spot window with the last 20 or so DX entries like RUMlog Classic allowed you to do. I used to be able to do SH/DX command in the DX Cluster window and the stations listed would populate the DX Spot Window (although, to be honest, the behavior was eratic and sometimes the stations would disappear from the DX Spot Window later on). Having the DX spots populate gave me an idea of the recent DX activity and would then allow me to directly QSY to a station by double-clicking (Although I realize that these spots were old). The way it is now, one has to wait for all the spots to come across one by one. Is there a similar way of populating the DX Spot WIndow in RUMLogNG?
When doing a LoTw QSL OUT function to upload worked stations to LoTw I notice I now need to highlight/select the QSOs I want to upload or it just sends the one that is currently focused on (usually the latest entry). In my case I always want to upload into LoTw all the stations that I have worked that haven't been sent previously. Is there any way to do that or do I just need to keep highlighting the QSOs I want to send? In the RUMlog Classic, it would ask if you want just the current highlighted entry or all the ones not yet sent.
Thanks for providing a great program. I am enjoying it very much.
Jerry AC4BT
Re: Clicking on DX in the DX Spot Window
Posted: Sun 22. Mar 2015, 15:39
As far as I remember it is the same behavior in the classic version. I want to take over data into the log by clicking on a spot without retuning the trx. I use it very often.
This function is not implemented (yet).
When there are selected QSOs in the log table, only these QSOs are affected and uploaded regardless of the QSL status. If you want to upload all new QSOs, make sure there are no QSOs selected. Only QSOs with the status 'W' will be uploaded.
