TS590S CW Window Message
nn5ee
Unread post by nn5ee »
Noting LA0FA's post for the FTdx5000 cw memory, I explored the TS590S/RUMLogNG 1.0.9 CAT keying interactions further. I don't use the TS590S internal keyer much but I do see that the CW window always says "CW interface not available". I can send from the RUMLogNG Software CW memories or from the keyboard as documented but that message is confusing.
Re: TS590S CW Window Message
Do you have set TRCVR as CW interface in the CW preferences? At this place you should read the actual CW speed.
nn5ee
Yes, "Transceiver" is set as CW Interface in CW menu.
