TS-590SG Frequency Readout
N1JM
Unread post by N1JM »
When turning the VFO the frequency readout in the log does not change. Should it? If I do a reset CAT the frequency will read what the radio says but still will not change with the turning of the VFO. Quite sure CAT:Serial port is set up correctly in preferences. Also none of the DX spots from the DX-Cluster terminal window show up in the DX Spot window.
73, John N1JM
ddanecki
Re: TS-590SG Frequency Readout
Unread post by ddanecki »
TS-590 has 2 VFOs. RUMlog seems to be able to read frequency out of VFO A. If you have by any chance enabled VFO B, outcome will be exactly as you described. Please check first if changing to VFO A helps, and let us know.
de SQ2KLU
Daniel
Check your flow control settings. As far as I know, the TS-590 uses RTS/CTS per default.
When you don't see dx spots in the dx spot window, check your filter setting in the preferences under the DX-Cluster tab.
N1JM
DL2RUM wrote:Check your flow control settings. As far as I know, the TS-590 uses RTS/CTS per default.
BTW the 590 works fine with the same settings in the old Rumlog.....8N1 56700 RTC/CTS but new Rumlog still will not change frequency when rotating VFO knob (VFO A).
The filter settings cured the DX spot window. Thanks.
73, John N1JM
Can you post a screen shot of your TRX settings please?
N1JM
I've attached a screen shot of the transceiver set up.
John N1JM
My error, try the latest version please: http://dl2rum.de/RUMlogNG/RUMlogNG.zip
For an unknown reason, I removed some code after successful testing.
N1JM
Excellent. Works great now.
Thanks and 73, John N1JM
