Logging via applescript
Posted: Sat 10. Jan 2015, 23:17
by SM0THU
I'm writing a program to interface WSJT-X with RUMlog.
Applescript is used to save a QSO to RUMlog. That works great for call, reports and locator.
But I'm missing the possibility to set date,time, frequency and power
Would that be possible to add?
Re: Logging via applescript
Posted: Sun 11. Jan 2015, 10:49
For logging RUMlog uses the date, time and frequency seen the the corresponding fields. Normally the current date and time will be used and the active frequency from the transceiver.
I can add more commands if required, maybe next week when spare time it allows.
Posted: Sun 11. Jan 2015, 14:49
by SM0THU
Date and time would be fine to use from RUMlog. The difference wouldn't be that much. But since WSJT-X needs to be connected to the transceiver, the frequency is not available in RUMlog. So that and power would be great if they could be set with applescript.
Posted: Wed 14. Jan 2015, 11:39
Find here the updated RUMlog:http://dl2rum.de/rumsoft/RUMlogApp.zip
The added commands are very basic. The given frequency must be in Hz, the power in W or as text. To remain compatible you should use only:
  • High Power
  • Mid Power
  • QRP
  • 2xQRP
  • QRPP
  • Unknown
tell application "RUMlog"
	Frequency (14195000)
	Power (100)
end tell
or:
	Frequency (7007000)
	Power ("QRP")
end tell
Posted: Wed 14. Jan 2015, 18:39
by SM0THU
That works perfect. Thanks a lot.
