Command cluster
Posted: Sun 15. Jun 2014, 18:08
by iz4ayb
Hallo! I have one question. I haven't possibility for use the command into the menĂ¹ "Command Cluster". They are all grey, I think disability, but I have regular connection with the cluster (via telnet with K9USA).
Why...? :?:
I send a picture's menĂ¹
Thanks a lot! Dan.
Re: Command cluster
Posted: Sun 15. Jun 2014, 18:25
Do you have tried "Edita le Macro..." ???
Re: Command cluster
Posted: Sun 15. Jun 2014, 18:42
by iz4ayb
Yes...it's only function operative, but the other not run.
For example "announce the last QSO" it's disability, Macro1..2..3..ecc. it's disability...where is the problem...?
Re: Command cluster
Posted: Sun 15. Jun 2014, 19:04
Do you have entered a macro and a name for it?
Re: Command cluster
Posted: Mon 16. Jun 2014, 08:33
by iz4ayb
I have only two macro edited, but i can't see the name and the macro not run...
I'm interested the function the first command, for announce the last qso logged, but this function not run also...
Re: Command cluster
Posted: Mon 16. Jun 2014, 09:48
To use the macros you need an open telnet connection. To announce a logged QSO you have to log a QSO first. After that the menu item will become active. Have a look into the terminal window. Do you see your defined macros?
Terminal.tiff
Terminal.tiff (55.54 KiB) Viewed 9240 times
Terminal.tiff
Re: Command cluster
Posted: Wed 18. Jun 2014, 07:04
by iz4ayb
I solved the problem
The menus are disabled in the telnet window that opens automatically when the program starts.
If I open a new telnet window, the commands work regular.
Thank you, Dan.
