QRZ.COM image screen possible detach/make it bigger?
m0pkz
Unread post by m0pkz »
Is it possible some how to make it QRZ.com image bigger on the side or is it possible to detach this window with map/picture/details (separate)? If no would it be possible in the next versions make this possible please :?:
Regards, Kes. m0pkz
N3PPH
Re: QRZ.COM image screen possible detach/make it bigger?
Unread post by N3PPH »
As a workaround I use look at http://dl2rum.de/forum/viewtopic.php?f=4&t=544
It is a bit of a PITA but you can keep the script editor window open and whenever you add a call to the log window run it. It will kill your existing Safari window and open qrz lookup in a fresh one. If you resize and place Safari where you want it on your screen it will reopen in the same spot.
Bob N3PPH
