Page 1 of 2
RUMped 2.0 Beta 16 with Yaesu Support
Posted: Thu 5. Jun 2008, 11:31
RUMped 2 has a great new feature: Using the 'ContestMaker' you can define your own contests to make RUMped more flexible. These contest definitions are made as a plugin type for easy distribution. Using this tool a wide range of contests becomes available for RUMped.
Please note, it's still Beta! That means it may not work correct. As you can believe, there are a lot of combination of contest rules, which it makes it impossible to test it all. BTW, your logged QSOs should be always safe.
Please feel free to report any failure .
Other requested features will be added in 2.0, stay tuned.
Download here: http://www.dl2rum.de/rumsoft/RUMpedBeta.zip
New in Beta 4
Posted: Fri 20. Jun 2008, 14:21
Found the following new features in RUMped and ContestMaker:
  • User Manual for ContestMaker added
  • In ContestMaker you can create your own sets of Multiplier lists
  • New Real Time Multi Check Window
  • Multi Check for Correctness
  • Cabrillo Log Import
  • User Selectable Key to Start the Exchange
  • Auto CQing
  • Speaking Call Check Result
Please refer to the 'User's Manuals' and to the 'What's new?' file for further details.
First VHF contest integrated
Posted: Tue 5. Aug 2008, 16:50
Especially for our european friends I have added the IARU Region 1 VHF/UHF/SHF contests. Also the master call database was changed. Read the provided 'What's New' file: http://dl2rum.de/rumsoft/rumpednews.html
VHF-Contest.tiff
VHF-Contest.tiff (582.61 KiB) Viewed 19684 times
VHF-Contest.tiff
Re: RUMped 2.0 Beta 7 with VHF contest !!!!
Posted: Mon 8. Sep 2008, 18:50
by N8NOE
Tom, Just saw the Beta version, and the Contest Maker is GREAT!..
I need to get the hang of making what I want and check this out more from home.
I'm at work and was pointed here by some friends..
KUDOS!..
And Many Thanks!..
The last Contest I'd lost the log as CocoaModem didn't output into a Cabrillo
so I'd retype the log or try and get it from the XML, this is my answer now. I
did use RUMped in the Russian WW RTTY contest, and again forgot what I was missing,
This is great..
Jeff-N8NOE :o
Posted: Tue 9. Sep 2008, 05:01
Thanks for the nice words Jeff. When you was successful in the contest, I would ask you if it is possible to share the contest definition file? It's still Beta, but I have not got much response.
I thing, it it is a good idea to collect and share the tested files here, maybe in a separate thread or forum.
Posted: Tue 9. Sep 2008, 10:41
by N8NOE
Started a Thread, Lets see if a Few contests get posted? Love to see this happen and could be very much fun.
If every on makes just one contest file, or helps debug someones this is all good..
Again Tom, THANKS for all the work!
Jeff-N8NOE
Re: RUMped 2.0 Beta 9
Posted: Thu 11. Sep 2008, 11:57
New in Beta 9
• For Cabrillo output you can define a 'Dummy', when there is no entry logged, required for some contests
• For the RX Control number you can define now rst+fix+fix, required when there is a space in the control number to log
Re: RUMped 2.0 Beta 10 with Band Map
Posted: Fri 12. Sep 2008, 11:40
New in Beta 10
• Band Map added - See http://dl2rum.de/rumsoft/rumpednews.html for further info
• RTTY Call sign recognition for calls in the master database works again, was broken since Beta 7
• In RTTY or PSK use now Command double click on a call to start exchange
RUMped_BandMap.tiff
RUMped_BandMap.tiff (26.68 KiB) Viewed 19585 times
RUMped_BandMap.tiff
Posted: Fri 12. Sep 2008, 15:41
by N8NOE
Tom, You are running in LEAPS-N-Bounds.. Seems you been busy. I have been in touch with Dick and he's running during the day,
So I might get home after the office here and know what to look at. THANKS!.. Great work on the CQ WW RTTY Exchange also, Sorry I didn't drop a note sooner but just been busy here. Hope we can get a bunch of contests all set and going over a little time here and make this a easy thing for everyone.
Thanks again, Jeff-N8NOE
Re: RUMped 2.0 Beta 11 with smaller changes
Posted: Fri 19. Sep 2008, 17:55
I 've changed RUMped and ContestMaker for a better WWDX RTTY support. It is now possible to swap the ctrl number order in the Cabrillo output. Load the WWDX RTTY file and see the Cabrillo tab in ContestMaker, how it works. Note the position numbers. Now you can sent and log the control numbers as required in the rules: first the state then the cq zone. The Cabrillo will write the cq zone first and after that the state. For outside NA the 'dx' will be added automatically. The Zones are not counted as multipliers for NA, RUMped can not handle three multis yet! Ignore the "New Multi" alert for the zones in NA. The Cabrillo file should be correct now.
Also it is possible now to define a control number as multi, when it is not a serial number. This is required in the CIS DX RTTY contest:
http://www.cisdx.srars.org
The latest CIS and WWDX RTTY files are located in the Plugins folder.
