Can't connect to TS-590S
Posted: Mon 3. Feb 2014, 15:57
by m0pkz
Hi everybody! Checked all the settings but still no luck to connect to my Kenwood TS-590S ? Any ideas? Thank you, Kes.
Re: Can't connect to TS-590S
Posted: Mon 3. Feb 2014, 16:16
Do you use USB or a serial interface?
Do you see the transceiver in the Port popup menu?
Posted: Tue 4. Feb 2014, 10:22
by ddanecki
Here are settings I use with my TS-590 and RUMLog. It works perfectly.
TRCVR: TS-590/TS-2000
Port: cu.SLAB_serial (or something similar, can't remember exactly)
Baud: 57600
Bits: 8
Pairity: None
Stopbits: 1
Xon: unchecked
Set RTS, Set DTR: unchecked
Use CTR, Use DTR: checked
Make sure that the Baud is identical as in TS-590 settings, for USB port it's item number 62 in TS-590 menu. Default transceiver Baud is 115200 bps.
Also, please note that you can choose correct serial port only if your transceiver is connected via USB to your Mac.
Did you install serial port drivers ? If not here they are:
http://www.silabs.com/products/mcu/page ... ivers.aspx
I hope it will help.
Posted: Wed 5. Feb 2014, 12:18
by m0pkz
Hi Daniel.....Thank's for info. Will try tonight. How is CW training going?
Kes m0pkz
Posted: Wed 5. Feb 2014, 12:34
by ddanecki
Hi!
Pretty well
Actually my qrz.com info is a little bit outdated already.
I quite often start in CW contests using ~30wpm.
However open text reading is still really difficult and unless my corespondent keys with 15-18 wpm I'm having a lot of trouble to catch up.
Posted: Thu 23. Oct 2014, 16:06
by NY3M
Thank you, Daniel SQ2KLU.
Your post with appropriate driver and settings made my brand new TS 590s work with RumLog like a charm.
Bill NY3M
Posted: Fri 24. Oct 2014, 18:41
by ddanecki
I'm happy to hear it
It's a really nice TRX, I'm certain you will be happy with your new toy
