Applescript
Posted: Mon 11. Nov 2013, 20:28
by LA0FA
RumLog 5.2.6 does not accept the logging from CocoaModem of the MFSK16 mode ... works will all other modes available from Cocoamodem, except MFSK16. I have ticked on MFSK16 as a mode in Rumlog preferences.
73 de LA0FA
Re: Applescript
Posted: Mon 11. Nov 2013, 22:55
Yes, the AppleScript provided in the RUMlog folder dosen't support this modem. I have to add this. When somebody is familiar with AppleScript, he can do it himself.
I will add this soon when time allows. Currently I'm fighting with more annoying problems.
Re: Applescript
Posted: Mon 11. Nov 2013, 23:56
by LA0FA
I was unclear.
I am familiar with Applescript and I have changed the script to include MFSK16 and I have verified that MFSK16 is sent as text string as mode to RumLog .. but Runlog won't log it. There must be a bug within the RumLog software.
Here the script I use, it works for all modes, except MFSK16:
tell application "cocoaModem 2.0"
set theCallsign to callsign of qso
set OpName to operator name of qso
set theMode to modemName
if the theMode = "psk modem" then
set theMode to modulation of transceiver 1 of psk modem
end if
if the theMode = "hellschreiber modem" then
set theMode to "hell"
end if
if the theMode = "mfsk modem" then
set theMode to "MFSK16"
end if
if the theMode = "rtty modem" then
set theMode to "rtty"
end if
if the theMode = "wideband rtty modem" then
end if
if the theMode = "dual rtty modem" then
end if
end tell
tell application "RUMlog"
Callsign theCallsign
Name OpName
Mode theMode
delay 2
Save
end tell
Re: Applescript
Posted: Tue 12. Nov 2013, 00:35
Oh, very fine! This saves a lot of headaches for me.
The mode was not transferred to the mode field. Without a mode, RUMlog will not save a QSO. When I made this routine, the MFSK interface was not included in cocoaModem.
I disabled the mode check now and the Applescript is responsible for the correct ADIF conform mode transfer!
Try this:
http://dl2rum.de/rumsoft/RUMlogApp.zip
Re: Applescript
Posted: Tue 12. Nov 2013, 19:45
by LA0FA
Thank you very much!
Works perfectly with the script.
Matthias, LA0FA
