ESM works for S&P but not for RUN
Posted: Wed 9. Oct 2013, 16:14
I am running RUMped on OSX 10.8.5 on a Macbook Pro. Everything works well connected to my K3 and USB Winkey except for RUN with ESM.
When I put in a call sign in RUN + ESM mode and press return, the keyer only sends the first letter of the call sign. If I press return again, it sends the second letter and so on . So if the call I enter is N1ZZ and then I press return 5 times, after the 5th return the Run message is sent. If the run message is blank I still get the callsign one letter at a time.
Can anyone explain what the problem is please?
Also what does the %CORRECT message do?
