Band Map
NA4M
Band Map
Unread post by NA4M »
Perhaps I've overlooked this somewhere.
Is there a way to change the behavior of the Band Map to lock the red current VFO freq indicator in the center of the window and have the VFO frequency scroll up/down?
Always having the VFO indicator in the center of the scale allows easier viewing of stations above and below the current VFO frequency.
73 Phil NA4M
Re: Band Map
No!
You can scroll the band map using the mouse, this may help a little bit.
