Cannot open log on startup
PG2W
Unread post by PG2W »
Rumlog shows a message: cannot open log at startup.
Does anyone know where to look for the log file?
I've been looking in the rumlog folder I cannot find a file that holds all my qso's.
What is the file's name?
Problem is solved, so consider this post as not posted :-))
Found a .rsd file in de documents folder which is up to date.
Regards,
Wouter / PG2W
Re: Cannot open log on startup
The same requester should show you the last used log file. The full path is written.
LogFile.tiff
LogFile.tiff (30.73 KiB) Viewed 4073 times
LogFile.tiff
