Moving LoTW QSL's to Rumlog
Posted: Mon 14. Jan 2013, 12:32
by jweisskohl
Is there a way to move confirmed QSL's on LoTW to Rumlog without having to manually enter them? I have about 300 QSL's on my LoTW account that are not in Rumlog. These QSL's are from the late 1990's and early 2000's. I want to have all the QSL's in one place so I can see which DX stations I may need and have an accurate accounting of what DX has been worked and recognized by ARRL. These QSL's show up in the QSL section of LoTW so I was wondering whether there was some way RUmlog could access them. I am using the feature in Rumlog that downloads and updates new QSL's that come into LoTW.
Thank you,
Jerry - AC4BT
Re: Moving LoTW QSL's to Rumlog
Posted: Mon 14. Jan 2013, 15:09
I would download the full LoTW report from the ARRL LoTW web site. Make sure, you set the option "Include QSO details". Since it is an ADIF file, you can use the normal RUMlog ADIF Import routine to merge the logs.
After the import, set the "Last QSL date" under the LoTW/eQSL tab in the RUMlog preferences to the date of your first QSO. Then do a normal LoTW QSL download. This is to ensure, you have the correct LoTW QSL status in your log.
It is recommended to backup your log file first.
Posted: Mon 14. Jan 2013, 22:25
by jweisskohl
Thanks!! That worked great. All my Arrl QSL's are now in Rumlog.
Thanks for your help!
Jerry - AC4BT
