New to RUMPed
Posted: Fri 28. Sep 2012, 20:18
by NF4L
I thought I'd try RUMPed this weekend in the CQWW 'test. I'm using a K3, no interface, AFSK A.
1) How to key the K3? I have set the modem to K3(Tx + cM(Rx). The macros don't respond to %TX %RX like RUMLog.
2) The DX spots item in the Window menu is disabled. I can't connect to a cluster. I have entered one.
3) I don't understand how to handle the state/zone in the exchange. I read the post in another thread about it.
73, Mike NF4L
Re: New to RUMPed
Posted: Fri 28. Sep 2012, 21:13
Use the CQWW-RTTY contest template (plug in type) when creating the contest file! Enter first the Zone and then the State separated by a space.
To see the cluster, open the terminal first from Menu-->Window-->Terminal
To key your TRX use the VOX, or cocoaModem supported PTT options.
Re: New to RUMPed
Posted: Fri 28. Sep 2012, 21:56
by NF4L
Thanks Tom!
DL2RUM wrote:Use the CQWW-RTTY contest template (plug in type) when creating the contest file! Enter first the Zone and then the State separated by a space.
OK
OK
When I transmit from RUMPed, no tones are generated. Xmit from cM, tones are generated.
Re: New to RUMPed
Posted: Sat 29. Sep 2012, 15:29
by NF4L
OK, got it going using Preferences-->RTTY-->cocoaModem Wide modem with VOX on the K3.
73, Mike NF4L
Re: New to RUMPed
Posted: Mon 1. Oct 2012, 16:00
by NF4L
i worked the CQWW RTTY 'test and RUMPed worked great!
Does it use the same format DXCC.rsd file as RUMLog? Since my file for RUMLog is more up to date, can I just copy it to the RUMPed folder?
Is there a place (or could one be added) to type in text to send if something isn't in a macro?
73, Mike NF4L
Re: New to RUMPed
Posted: Mon 1. Oct 2012, 20:28
Yes, it's the same file.
There is a Keyboard mode provided: Menu-->TRCVR-->Keyboard Mode
Use the RTTY menu for PTT. While you are in the keyboard mode, you can start typing, but you have to select Menu-->RTTY-->Transmit first to start the transmission.
Re: New to RUMPed
Posted: Mon 1. Oct 2012, 21:43
by NF4L
Great! Thanks Tom.
73, Mike NF4L
