RUMped 1.2.1 - Cabrillo Export modified
In the Cabrillo Export Window a line feed option was added. It was found out, that the WPX contest robot did not except files with Mac linefeeds in the file, what the robot should do.
If you want to output a Windows conform Cabrillo text file, you can choose this option.
Cabrillo.tiff
Cabrillo.tiff (82.53 KiB) Viewed 6068 times
Cabrillo.tiff
Windows uses ASCII 13 and ASCII 10 as linefeed, the Mac uses only ASCII 13.
Read the supplied WhatsNew.pdf document for detailed information.
Download here: http://www.dl2rum.de/rumsoft/RUMped.zip
