Kenwood TS-480
Posted: Tue 22. May 2012, 16:53
After seeing a note in the cocoaModem board, I moved to try RUMped, but without success after much…
Despite all my attempts, RUMped seems not to 'see' my radio.
My hardware is a MacPro (LION) into a microKeyer II connecting to my Kenwood TS-480. Normally, I use MacLoggerDX, but would like to try RUMped, especially for the upcoming field day. So the base question is, should I be able to have RUMped interact with my TS-480? If so, can you identify the area where I have most likely misconfigured my setup? Thanks,
73 Brian
73 Brian
