New installation of Rumlog under Lion -preferences not saved
Posted: Thu 19. Apr 2012, 19:41
by g4sjp
I just performed a clean install of Lion on my Mac Mini. I saved my .rsd log file before I wiped the machine.
Now I find that I can open my old log file but there are two issues:
1. When I close and re-open Rumlog, it claims that no log file exists.
2. I cannot make connection with my K3, and no connection settings are stored after saving.
I have looked for Rumlog's .plist file mentioned in the User's Manual and cannot find one. I have also used disk utility to repair permissions.
Any ideas please?
Thanks, Stephen G4SJP
Re: New installation of Rumlog under Lion -preferences not s
Posted: Thu 19. Apr 2012, 20:16
I guess, during a clean install , all of your preferences were going lost.
You can find all personal preferences in ~/library/preferences. Starting with Leon, this folder is normally hidden.
Posted: Thu 19. Apr 2012, 20:33
by g4sjp
Hi Tom
Yes, I expected to lose all the preferences on a clean install, but my problem is deeper than that:
1. I can look through the /library/preferences but I see no reference to anything from Rumlog
2. More importantly perhaps, Rumlog is not saving its preferences on exit, because when I start Rumlog again, it does not know the log file or any of the other information saved from the previous session.
And then, there is still the problem that I cannot connect to the K3.
I do have the same version of Rumlog running without any problems at all on my Macbook, also running under Lion.
That is why I am confused!
73 Stephen
Posted: Thu 19. Apr 2012, 20:49
Oh well, there seems to be something wrong on your system. I assume a system failure. No idea yet. Are there other new dated files in the folder?
Posted: Thu 19. Apr 2012, 20:56
by g4sjp
Hi Tom
Yes, there are plenty of other entries in the preferences folder, dating from April 17 when I re-installed the OS until just a few minutes ago with another application. It is very strange!
Perhaps some more detail will help. I have an external hard drive which is permanently connected to the Mac. Before erasing Snow Leopard I copied across the Rumlog folder from Applications to the external drive. After installing Lion, I copied the folder back across to Applications again. After finding the problems that I have described, I deleted the folder and installed a clean copy from your website. This made no difference to the problems that I am experiencing unfortunately.
Everything else works fine!
73 Stephen
Posted: Fri 20. Apr 2012, 09:34
by g4sjp
Tom
I have things working now. I had to thoroughly uninstall Rumlog, using search to get all of the system files too. Now my fresh install of Rumlog saves its preferences okay and I am talking to the K3 successfully again.
I think that this could have happened because when I did a clean install of Lion, when I installed Rumlog again, I just brought across my old 4.9.1 folder from Snow Leopard which I had saved, thinking that I would not have to put all my preferences back in again.
Anyway, it is all now working. That will teach me for being too clever HI.
73 Stephen G4SJP
