How to add South Sudan as new DXCC?
Posted: Sat 30. Jul 2011, 17:15
Since the ITU hasn't assigned a prefix yet and there is no ADIF number provided, the following is unofficial:
Once an official prefix is assigned :
- start EditDXCC.app
- select the "DXCC" tab
- push the "Add Row" button to create a new entry
- click into the cells to enter the data. You have to click once to select the line and once to make the cell editable. But no double-click!
- DXCC: ST0 - or what ever, needs to be changed later
- Country: South Sudan
- CQ: 34
- ITU: 38
- Cnt.: Af
- ADIF#: 521 - is the next in sequence
- Locator: KJ54LL - example
- select the "Calls" tab
- click into the cells to enter the data:
- Full Call: ST0R
- DXCC: ST0 - or what ever you entered above under DXCC, these entries must match!
- Until: 2011-08-12
- push on "DXCC" in the table header to keep the table sorted by the prefix
- push the Save button
- restart RUMlog or use the "Reload in RUMlog" button when RUMlog is running.
- select all your QSOs with ST0R in RUMlog (use the call field on the bottom when Menu-->Logbook-->Show Search Options is checked)
- use Menu-->QSO-->Recalculate DXCC-->with zones
- change the prefix (ST0) to the 'main' prefix under the "DXCC" and under the "Calls" tab
- select the "Prefix" tab
- for each prefix (if applicable) push the "Add Row" button to create a new entry and click into the cells to enter the data:
- Prefix: the new prefix
- DXCC: the 'main' prefix
- To: 2030-12-31
- push on "Prefix" in the table header to keep the table sorted by the prefix
- push the "Save" button
