Table View Colors
Posted: Fri 22. Jul 2011, 20:30
by K6LE
I have noticed that when an unconfirmed spot (Entity, Freq or Mode) shows up in Text View it's displayed in the normal Amber color. However when that same spot is displayed in Table View it's in Yellow.
Not a problem now that I am used to it but seems a little strange.
BTW, Text and Table view are working out great for me especially since RUMlog can now connect to more than one Node.
Re: Table View Colors
Posted: Fri 22. Jul 2011, 21:10
Well, that's right. The original colours looked not very well with my defaulted back ground colours. (Gray-blue theme) That's why I changed the colours slightly. I have to add an option to make these colours user selectable.
Posted: Fri 22. Jul 2011, 21:15
by K6LE
Thanks for the quick response.
As I mentioned I it really isn't a problem, now that I am used to it, just a curiosity.
Posted: Thu 28. Jul 2011, 11:08
by w2nra
K6LE wrote:I have noticed that when an unconfirmed spot (Entity, Freq or Mode) shows up in Text View it's displayed in the normal Amber color. However when that same spot is displayed in Table View it's in Yellow.
I get the same here only it is ver hard to see the yellow against the pea green background. You'd think that such an important need, unconfirmed on any band or mode DXCC entity, should command higher contrast color scheme.
73 Art W2NRA
Posted: Thu 28. Jul 2011, 16:23
In the next version you can adjust the colours for your needs. Send a PM if you want to try it out.
