RUMlog 4.7.1 is available - Update
Posted: Tue 31. May 2011, 10:39
New in 4.7:
  • Tracking of Russian Districts
  • Tracking of French Departments
  • Advanced dx spot table view
The files 'RUMlog.app' and 'IOTA.rsd' were changed.
Download the full package: http://www.dl2rum.de/rumsoft/RUMlog.zip
Changes: http://dl2rum.de/rumsoft/rumlognews.html
Manual: http://dl2rum.de/rumsoft/RUMlogDoc.html
RUMlog is a logging, QSL handling and printing tool, especially made for the short wave DXer, made by a DXer. Basic logging features are included for the higher bands up to 1.2 cm and for satellite. RUMlog can handle an unlimited number of logs and an unlimited number of QSOs per log. An user editable, all time country database is used for automatic DXCC recognition.
Save your multi media data within the log book file using drag and drop.
RUMlog includes calculations, routines, tables and an interactive gray line map to support the user in gray line dxing.
Using RUMlog you can print QSL card and address labels on your favorite label size and manage your incoming paper QSLs. The Logbook of The World (LoTW) and eQSL are fully supported, and you can create files for the Global QSL service very quick. You can get different statistics for paper- or LoTW QSLs. It's just a mouse click to upload or download new QSLs to/from eQSL or LoTW.
RUMlog can use the ON6DP QSL manager database to inform you about managers or addresses and it can build and use an own manager and IOTA database, extracting the information from dx-cluster spots. Provisions are made to query the qrz.com online library. Save the retrieved data into the Mac's address book.
RUMlog keeps you up to date about worked, confirmed or missing DXCCs and provides you with country lists and detailed statistics. Quick log searches or more detailed log queries and export routines are possible.
RUMlog can establish multiple dx-cluster connection via the internet or to your local skimmer. A simple terminal is integrated for a Packet Radio connection. RUMlog will separate DX-spots and alert you via e-mail or Growl when there is a ,new one' DXCC or IOTA spotted. Multiple interactive band maps virtualize activities on the air. LoTW users are identified in dx-spots.
RUMlog can interface with two transceivers, setting the main parameter on your TRX from the logbook or vice versa. Kenwood, Elecraft, Yaesu, Icom and TenTec transceivers are supported. More controls are provided for the Elecraft K3.
RUMlog has import and export functions to allow exchange of log data in different formats to other logging tools.
RUMlog can interface with Google Maps (Web-Browser based) and Google Earth. (Must be installed on your computer)
Except the DXCC statistics, RUMlog tracks the most interesting areas of the world for the most important awards: IOTA islands, CQ zones, ITU zones, Grid Squares, US States and German DOKs.
Work CW, RTTY and other digital QSOs direct in the RUMlog application, using cocoaModem as interface. The data (log + trx) exchange with fldigi is supported. The WinKeyer and few microHAM devices are supported.
Re: RUMlog 4.7 is available
Posted: Tue 7. Jun 2011, 17:42
by IZ1TGH
Hello Tom!
I'm using Fldigi on another computer (with Ubuntu Linux) on the home network.
Everything works fine with reading the callsign and the mode (I work mainly digital, so it's VERY useful), but it doesn't work with reading or setting QRG.
My rig is a Yaesu FT-897D (CAT controlled inside Fldigi via RigCAT, since Hamlib is not working very well for me), but I think it makes no difference, since I think the problem is "talking" to Fldigi.
I've also noticed that you've added French and Russian departments, very well done!
Is there any chance to have also Italian provinces?
It would be very useful to track QSOs for the WAIP (Worked All Italian Provinces) Award.
[Wenn Du die Liste brauchst, gerne schicke ich Dir eine]
Many thanks for the great job, Tom!
RUMLog is (almost) perfect [*], it has been my "official" logging software since I got the licence and it's great for printing paper QSL labels.
73's de IZ1TGH Roberto
[*] It will be totally perfect if I could also log Name and QTH, but you said a year ago that it's not possible.
Posted: Tue 7. Jun 2011, 18:31
When your TRX is connected to FLdigi, you have to check only the option "Read TRX Data" in the RUMlog preferences.
I will do this.
Just put it into the Note field
Posted: Wed 8. Jun 2011, 10:57
by IZ1TGH
DL2RUM wrote:When your TRX is connected to FLdigi, you have to check only the option "Read TRX Data" in the RUMlog preferences.
Both Send and Read TRX Data are checked, but none works.
Fldigi is version 3.21.8 and on a remote machine on the same subnet.
I will do this.
Great!
Exactly what I do!
Thanks for your answer and again for all your work, Tom!
73's de Roberto IZ1TGH
Re: RUMlog 4.7.1 is available
Posted: Mon 4. Jul 2011, 14:33
New in 4.7.1:
  • Further Italian translations
  • Tracking of Italian provinces
  • When using RUMlog to operate RTTY or PSK, the correct TX frequency will be taken over into the logbook
  • RUMlog can poll the mode and frequency from FLdigi, useful when your TRX is connected to FLdigi
  • You can enter now your TX power as numerical
  • For TX control you can select now CW revers as default
Download the changed files only: http://www.dl2rum.de/rumsoft/RUMlogApp.zip
