New RUMlog 4.6 is available
Posted: Tue 1. Feb 2011, 15:46
New in 4.6:
  • QSL label editor added, print labels now on any paper size on any label format
  • Address label print routine added
  • Store multi media data now in your log file
  • Save data from qrz.com in the Mac's Address Book
  • Support for attached accounts in eQSL added
  • DX cluster spot filter options added
  • Option added to print/send QSLs for selected QSOs only. (Main Logging Window - Paper, LoTW, eQSL)
  • Option added to mark QSOs for resending QSLs in the Search Window (All found or selected ones only)
  • Option added to export selected QSOs only rather than the full list in the Search Window
  • Added more K3 controls
Only RUMlog.app was changed and the label-template folder was added.
RUMlog is a logging, QSL handling and printing tool, especially made for the short wave DXer, made by a DXer. Basic logging features are included for the higher bands up to 1.2 cm and for satellite. RUMlog can handle an unlimited number of logs and an unlimited number of QSOs per log. An user editable, all time country database is used for automatic DXCC recognition.
Save your multi media data within the log book file using drag and drop.
RUMlog includes calculations, routines, tables and an interactive gray line map to support the user in gray line dxing.
Using RUMlog you can print QSL card and address labels on your favorite label size and manage your incoming paper QSLs. The Logbook of The World (LoTW) and eQSL are fully supported, and you can create files for the Global QSL service very quick. You can get different statistics for paper- or LoTW QSLs. It's just a mouse click to upload or download new QSLs to/from eQSL or LoTW.
RUMlog can use the ON6DP QSL manager database to inform you about managers or addresses and it can build and use an own manager and IOTA database, extracting the information from dx-cluster spots. Provisions are made to query the qrz.com online library. Save the retrieved data into the Mac's address book.
RUMlog keeps you up to date about worked, confirmed or missing DXCCs and provides you with country lists and detailed statistics. Quick log searches or more detailed log queries and export routines are possible.
RUMlog can establish multiple dx-cluster connection via the internet or to your local skimmer. A simple terminal is integrated for a Packet Radio connection. RUMlog will separate DX-spots and alert you via e-mail or Growl when there is a ,new one' DXCC or IOTA spotted. Multiple interactive band maps virtualize activities on the air. LoTW users are identified in dx-spots.
RUMlog can interface with two transceivers, setting the main parameter on your TRX from the logbook or vice versa. Kenwood, Elecraft, Yaesu, Icom and TenTec transceivers are supported. More controls are provided for the Elecraft K3.
RUMlog has import and export functions to allow exchange of log data in different formats to other logging tools.
RUMlog can interface with Google Maps (Web-Browser based) and Google Earth. (Must be installed on your computer)
Except the DXCC statistics, RUMlog tracks the most interesting areas of the world for the most important awards: IOTA islands, CQ zones, ITU zones, Grid Squares, US States and German DOKs.
Work CW, RTTY and other digital QSOs direct in the RUMlog application, using cocoaModem as interface. The data (log + trx) exchange with fldigi is supported. The WinKeyer and few microHAM devices are supported.
FT-990 support added in 4.6.1
Posted: Fri 11. Feb 2011, 19:34
The Yaesu FT-990 was added to the list of supported transceivers. Tnx Anmari, N2YGG for testing.
Download here the application file only: http://www.dl2rum.de/rumsoft/RUMlogApp.zip
Re: New RUMlog 4.6 is available
Posted: Fri 11. Feb 2011, 19:43
by N2YGG
That was FUN, Tom. Thank you for all your hard work and efforts! I love all the changes. Bravo! -Anmari
Posted: Sat 12. Feb 2011, 00:18
by N2YGG
Hey Tom, were you thinking of developing support for the FT990 in RUMped?
RUMlog 4.6.2
Posted: Mon 21. Feb 2011, 13:33
  • RUMped ver. 3 log files can be imported (Menu-->Log-->Import RUMped)
  • More controls in the K3 window added. (S-meter for main and sub, RIT/XIT indication, memories, quick memories and direct frequency input)
  • Mainwindow will be hidden now when tqsl starts, so the tqsl window will be visible
Posted: Fri 11. Mar 2011, 11:49
by Sheldon
Hi Tom.
I am excited about version 4.6 - especially the label editor.
I am new to RUMlog and have not installed an updated version.
Can you tell me how to update from 4.4.15? I want to ensure my logbook entries are not damaged or lost during the upgrade.
Thank-you for supporting Mac ham operators!
Sheldon
VE1SJP
Posted: Fri 11. Mar 2011, 14:51
First at all it is a common practice to backup your log file frequently, even when you upgrade to a newer version. There is no installer provided, RUMlog will not install files on your Mac somewhere, except one or two preference files in your library/preferences folder.
Sometimes I have to change the log file database structure, due to new functions. Your log file will be modified and is not any longer useable by older RUMlog versions! This happened for the last time with the update to 4.6.0!
For you I would recommend the following:
  • Backup you log book file
  • Backup your existing RUMlog folder
  • Download the full package
  • Read carefully the "What's new" read.me
  • When you have modified or use own files in the LabelTemplates or Colours folder, copy these files to the new RUMlog folder
  • Copy the "Cluster.rsd" dx spot database file, when available
  • When you have a personalised version of the "DXCC.rsd" country database, copy this file to your new RUMlog folder
When you open now a log book file for the first time in 4.6 it is not longer usable by RUMlog prior 4.6!
When you upgrade more frequently, most of the time it is sufficient to download and exchange the RUMlog.app executable file only.
Posted: Fri 18. Mar 2011, 11:43
by Sheldon
Thank-you for the information Tom. It is appreciated.
Sheldon
VE1SJP
RUMlog 4.6.6 is available
Posted: Fri 18. Mar 2011, 16:13
A new RUMlog version (4.6.6) is available for download.
Version 4.6.6 - 18-March-2011
  • Support for IC-7200 added
  • microHAM USB CW Keyer conformed working
  • partly Dutch localzation
Version 4.6.5 - 1-March-2011
  • Corrections for the Ten-Tec Orion when using a microHAM device
  • Options added to enable CTS and DTR flow control for the TRX com ports
  • Option added for a quick view for all QSOs with one DXCC, just click into the DXCC info box
Version 4.6.4 - 28-February-2011
  • Corrections for the FT-990
